Invacom 4 port quad after storm stop to work
hello
after 3 days rain non stop lnb plastic broken
enter watter the lnb it gone
I try to found like this invacom 4 port quad for c120
or inverto black pro 49mm quad flange 4 port
where I can get it
Quad Flange 40mm LNB
any know shop are seal it
thanks for help
Unless the seals between F sockets and cable have not been waterproofed correctly the damage shown will not cause the LNB to fail.
It might be the receiver has shut down because of a short in the cable, which would be water ingress. If you have aircored cable then it needs to be replaced.
Invacom LNBs are extremely well sealed under the plastic covering, almost to Military spec. I echo CH's advice - check your cable and connections.
Terryl
Custom built PC
I had a bird problem with my Invacom LNB, (LNB eye was pecked out by wood peckers) I Emailed them about this and they sent a replacement at no charge, LNB was 3 years old.
Email them the picture and see what happens.
Tururu
Assembled with recycled parts
Recycled as the owner.
If you saw the break and covered with a plastic bag all/you can have moisture inside by the break of the lid.
For temperature difference, it will condense in drops of water, in these frequencies, deadly, let it dry well in a warm, well ventilated and dry environment for a few days.
No oven :-rofl2
Si viste la rotura y tapaste con una bolsa de plastico todo/puedes tener humedad dentro por la rotura de la tapa.
Por diferencia de temperatura, se condensar en gotas de agua, en estas frecuencias, mortales, dejar secar bien en un ambiente calido, bien ventilado y seco unos dias .
Nada de horno.:-rofl2
Terryl
Custom built PC
I just put them in an old nylon stocking and then cover them with a box of minute rice,(stocking keeps the rice out of the device) all this inside a large Tupperware container, this will suck the water our of most anything, give it about 24 hrs to do so.
Your nylon stockings ?
(No need to reply)
Terryl
Custom built PC
Yah...I buy them at Riteade, size XXXXXL wide, (panty hose) other uses for them are to help put on a wetsuit when it's wet, you slip right in, don't have to wait it out to let it dry.
Ladys at the counter always give me funny looks.
I check the cable is ok
the problem lnb enter water
any now I cant found lnb quad 4 port inverto any know shop to shop online ?
