is it possible to get PAS 10 at 68.5°E in uk?
coloureye
1.2Cm dish, Motorized, TM1500CI+,dragon cam,SS2....
North england
where may i find the footprint for this satellite
and if ok how big dish shall i use
thanks
It is very, very low on the south eastern horizon, You would need an almost ideal horizon to stand any chance of getting it - so if you have any hills out to the south east, tall buildings, tall trees, forget it.
Footprints for various frequencies here:
http://www.lyngsat.com/pas10.html - right hand columns
coloureye
North england
thnx Analoguesat
do u mean i have to put it like this?
Yes, with absolutely nothing in the way of the dish, not even a slight incline.
Weather will also have an impact on the final reception, as a result of the extre atmosphere the signal has to go through, as well as ground noise.
It all depends on where in the UK you are as well, SE is always best, once you get to Manchester, you may as well forget it.
H
Happy-Buddah
I was thinking of trying to get permission to put up a dish on top of the lighthouse at St Catherine's point on the Isle of Wight to improve my seeable arc.
H-B:-idiot
From Suffolk (Isle of Wight ?) you should see everything up to about 73 degrees East and West of your location.
Lancelot
Retired Mod
SS1.
36v H to H 62E - 61.5W
South central
If only I had a lighthouse to put stuff on...:D L.
