itv2
dynamo985
What are my options for receiving itv2, would it be possible to connect my receiver to my aerial and receive it that way? or is that just plain stu[id and wouldnt work, wot do i need to do?
dynamo985
back to my original point:
prof
In the spare room.
@educabrera This question has already been answered and the answer is NO. There is no need to hijack some-one elses thread.
Depends what receiver you mean. Sky digibox to dish - only if you have a Sky subscription.
Freeview Box to terrestial aerial :- Yes
dynamo985
ok im off to buy a freeview box in time for the match on itv2 tonight :)
will i be able to get itv2 just by plugging it in or will i need a booster or some sort of physical altering to my aerial?
my postcode is rh13 9hz
incase u need a location reference.
cheers
gameboy
Ding Dang Doo
www.gamezplay.org
Scotland
BGonaSTICK
Dreambox 7000, Skystar2
Brighton
Now you've watched tonights match, you should do some more investigation into your Freeview options.
Have a look at http://www.dtg.org.uk/cgi-bin/pcode/coverage_detail.pl?postcode=RH139HZ&ant=YES
My parents live near you, and can get most of the popular channels (inc ITV2, even though the site checker says not) except Ch4.
Borrow a mates box, and try it out.
Most stores won't let you return Freeview boxes once bought, for the above reason, so be carefull to check before you buy one.
You can improve your chances dramatically with a decent Freeview wideband aerial.
And an unbroken run of good cable such as CT100 works wonders as well.
dynamo985
do your parents have a better aerial or just their normaly bog standard one like mine, cos all i want really is itv2, if i can get that im gd!
BGonaSTICK
Brighton
It's nothing special, 'bout 9 years old, and pointed at Midhurst.
I wouldn't put too much credence in the postcode checker, if you phone a local aerial installer, he will know whether you will be able to receive digital channels.
