Ive Got A Dreambox 5620 And I Need Some Keys For Sky Tv And Uk Terrestrial Tv Please
K
kirit
Likes
TRIAX 1.5M DISH
DREAMBOX 5620S
tripple LNB- 19,28.2, 13e
now actively CS
Harrow, Middlesex, Greater London
#1
grateful if somebody could point me in the right direction as to where to get these keys for the dreambox 5620 specially for sky and stuff like ITV, C4, C5 and freeview channels.
also any idea of software to use to get the keys into the dreambox please
cheers people
closetosoton
closetosoton
More dishes than Sense.
Likes
Wavefield T55, 20 LNB's and a whole load of analogue boxes!
Close to Southampton
#2
can't be done, unless you have a digibox to clone & FTV card. suggest you get a freeview box :)
you're really jumping in at the deep end, suggest you do some backround reading before you post, this is a good place to start:
_http://www.satellites.co.uk/php-bin/forum/showthread.php?t=38282&highlight=sky
.. but only if you know your dreambox inside & out!
-cts
PS - note you have LNB's (Low Noise Block), not LMB's :)
_http://en.wikipedia.org/wiki/Low-noise_block_converter
E
eghamhigh
Likes
echostar 808 2CI
Matrix Reloaded Cam
Fixed dish 13E
Surrey/Berks Border
#3
I cut this out of another thread that seems to be referring to the same thing as you.
http://www.satellites.co.uk/php-bin/forum/showthread.php?t=40166
It is at the moment (with a little messing around) possible to use a Sky subscription or FTV card in your Dreambox, but for how long, who knows?
You can't add keys as it isn't hacked. There is a softcam called Newcamd which allows you to use your Sky or FTV card in your Dreambox, there are a couple of threads about it in the Dreambox section.
