Jaeger SMO 36 Dual Axis Motor!,5.wire nesersary?
Turok
Turok
Likes
1,25 Fibostop
Jäger Smr 1224 & Smo 36 Dual Axsis Motor
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Tagra 2,20 M Fullsize Dish
Echostar 2,40m Mesh for cband!
Austria
#1
Hello!
i have an Jager Smo 36 Dual Axis Motor,that was included,in a ebay Auktion of 240 cm Echostar Mesh Antenna!
now,i see 5 Wires,in this motor,but the paper,of the schematic,inside,the motor is missing,can anyone tell me,is the 5.conection wire nesersary,to controll,and what it use for?
can i conect it to my dvr 7000 echostar,or is the new,vbox 3 needet,to controll,the motor?
i install the system,in aproximently one mounth,the antenna itself has 12 pcs,ans 14 wires per panel.so many man work to do!:)
Likes
5,957
UK South
#2
if the Echostar 7000 has a 5 V rail on the back section , and software that allows permanent connection to 5 V, then you will have no problems.
M
markrankin
Likes
Satellite
#3
Hello:
Could you help me?. I have the same problem. I use a positioner with Motor+/Motor- , Sensor+/Sensor-.
Marky.
M
Mickha
Likes
568
#4
You need to open the casing, on the motor, and make a note of which wire is connected to which connection, then match them correctly to the positioner.
