kaon ksc 570 - big problems
Likes
xxxx
I am having real problmes updating my set. I have been told that I could be using the wrong software.
How can I tell exactly which model and board I have to make sure I get the right one ? All it says on the tin is KAon KSC 570.
Is there one set of software to load or are there several different parts ?
Is it true that if you use the wrong sofware you can mess up the whole set up ?
Thanks for your help
PCD
DB Magician
Likes
You will find the HW (hardware) number in the menu-system info. Kaon KSC570 has many hw versions :-
HW 12.01.A1
HW 12.c1.A5
HW 12.A1.A5
HW 12.41.65
HW13.01.65 and
HW 13.14.65
You must get the software for the exact HW of your stb, otherwise it may be fooked !
The software comes as one file and always has the HW number in the name.
Regards, pcd.
