Keygen
john_graydon
Dublin....Ireland
Downloaded a programme and has a keygen with it, How does this work and a how to if anyone could help please.
Normally it's just an exe file and when you click on it there is a key generated to copy and paste.
john_graydon
Dublin....Ireland
Thanks Rolfw, do they always work or are they hit and miss.
I've had a few which haven't, but you need to check that they are for the correct version number.
d122k7trb
Judas Priest
IClass Receiver
2 Premium X LNBs Hotbird+ Nilesat
120" Dish
Computer system:
AMD Phenom Quad quad core 9750
4GB DDR2 Bus 800 RAM
MB: Asus Crosshair
1 TB Seagate Barracuda 32 MB cache
22" LCD Widescreen Samsung 226BW
SB X-Fi Xtreme
Armenia, ME: The Arab Countries
Keygens depending on the program are a kind of id or user (serial) number. They work almost always but on many programs one cannot upgrade or register the program. that's the point.
Please do not use that kind of programs that much.
Noobie
Lemon 030-CI
Belgium
There is also a small program, called Cracksearcher, wich will allow you to find a lot of keygenerators or patches to solve the problem.
If a patch doewn't work, you just try the next one.
This program can be downloaded if you look for it on the Net with your favorite search engine.
porky Butts Sr
Visiting *****/Mod
Big Bad 64k With All The Trimming's
Hog Barn
Another proggy that you can use outside of CrackSearcher is one that is called CrackDown by HiSoft V.1.0.2.1. They are both equal and reliable. At the present time they seem to be the 2 best one's out there to obtain what may be needed by you. Thank you,. Porky Butts Sr.
