Lacuna/apollo Dtm 2000 Help Please
D
dtakias
Likes
I have purchased a second hand Lacuna/Apollo DTM 2000 satellite meter from ebay: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=5732638906
I am looking for some support for this product.
First i need to purchase a battery pack and a dc adapter.
Do you know what are the specs of the battery pack or dc adapter and where can i get them from?
Also on the side of the unit there is a port(looks similar to rj11) which i
believe is for programming the unit with satellite information.
Can you supply schematics for the cable that needs to be used?
What about software?
Any help would be really appreciated.
regards
T
Tony Baker
Likes
dtakias said:
regards
I have the same meter and have just replaced the battery in mine, all you havbe to do is to contact the Lacuna Co on the Isle of Wight and they will send you a replacement Battery or send it to them to replace the Batt and get the latest update, you will also be able to get the correct charger.
Regards,
Tony Baker.
