Lidl UK selling satellite equipment - 1st September
gameboy
Ding Dang Doo
Likes
5
Scotland
#1
Following the Europe offers it's coming to the UK - get in quick and grab a bargain...
Digital Satellite Dish & receiver Set (Silver Crest)* - £59.99
Complete satellite set, consists of
- Satellite steel offset dish (57cm)
- Digital satellite receiver with remote control
- Twin LNB
- Wall bracket
- Cable set and satellite finder
- flat cable extension (no need to drill window frame)
Receiver features include:
- Plug and Play
- Auto search with 4500 programmable channels
- MPEG-2 and DVN compatable
- OSD (on-Screen-Display)
- Super Fast Teletext, 800 pages
- Software update via satellite 'Astra 19'
- Multi Function Timer
- Coaxial, Optical and S-VHS connection
- Pre-programmed satellites: Astra, Astra II, Eutelsat Hotbird, Turksat and Hispasat
- Supplied with SCART cable and 2 x F connectors
- 3 Year manufacturer's warranty
Digital Satellite Receiver (Silver Crest)* - £39.99
- Free-to-air receiver in slim line design
- Remote control (including batteries)
Universal Single LNB - £3.99
Frequency level:
- Low Band: 10.70 - 11.70 GHz
- High Band: 11.70 - 12.75 GHz
Noise level: 0.6 dB
In plastic weather proof casing
Satellite Finder - £3.99
Easy to use satellite finder
Connect to LNB and satellite receiver, slowly adjust sensitivity level and align dish.
LED level indicator and acoustic signal to show optimum reception
Includes 30cm connection cable
Satellite Dish - £14.99
Ofset angle 25 degrees
Elevation range: 15 to 65 degrees
With 40mm LNB Holder
Supplied with wall bracket and fixings
Wall Bracket for Satellite Dish - £2.99
Sturdy U-Shaped galvanised steel construction with mounting base
Supplied with fixings
Size; 25cm x 35cm
*Strange tagline - Can be used to receive Sky but will require a subscription to the service?
Receiver looks like a Comag SL 65....
BadWithComputer
The Local Drunkard
Likes
30MB ADSL ONO, Spain
32" Internet connected TV
Many Satellite Dishes.
Humax HD Freesat Box
Spain
#2
I bought the sat finder, dish and the wall bracket and the LNB. Excellent value. They were on sale at about a pound cheaper than yours in england.
gameboy
Ding Dang Doo
Likes
5
Scotland
#3
And in Scotland! O-Ha
mick2me
Likes
'Fortec Star Passion' (& a dead SL65) One of them big Woks on the outside, and a thingy that moves it about a bit.
Nottingham
#4
OK, So I got a Freeview Box,
Q1. Do I get any extra channels from this satellite Receiver?
What channels will I receive on this box?
Q2 There are two systems. Complete system at £59.95 or Receiver + Dish (£39.95+£14.95) Which is the best to go for? Are both receivers the same?
http://www.lidl.co.uk/gb/home.nsf/pages/c.o.20050901.p.Digital_Satellite_Dish_Receiver_Set
http://www.lidl.co.uk/gb/home.nsf/pages/c.o.20050901.p.Digital_Satellite_Receiver_
http://www.lidl.co.uk/gb/home.nsf/pages/c.o.20050901.p.Satellite_Dish
Q3 Is it worth buying the seperate satallite finder, or is the one in the complete kit adequate?
http://www.lidl.co.uk/gb/home.nsf/pages/c.o.20050901.p.Satellite_Finder_
gameboy
Ding Dang Doo
Likes
5
Scotland
#5
mick2me said:
Q1. Do I get any extra channels from this satellite Receiver? What channels will I receive on this box?
When you say extra channels - you will get any free-to-air channels transmitted from the satellites you point the dish at. This will depend on the dish size and area covered by the FTA channel. Check lyngsat.com. I think this receiver is made by Comag and previous receivers have been patchable to receive 'extra' channels on some satellites. No guarantees as I haven't seen any patches for this receiver - yet!
The complete system include a smaller dish and dual LNB - may be worth it to start you off. The larger dish will help but you will also have to buy the LNB (included in the package). Both receivers are the same.
Q3 Is it worth buying the separate satallite finder, or is the one in the complete kit adequate?
As the meter is only £3.99 I would buy it - amazing how much time that will save you. You can't watch or hear the TV from up a ladder where the dish is. It can be done but the meter will make it a lot easier.
Better get in before me, as I plan to get as many meters as I can get my hands on - then sell them! We I am Scottish.
gameboy
Ding Dang Doo
Likes
5
Scotland
#6
Support site. with downloads. for SilverCrest receivers (Comag)here
mrgentry
Likes
NONE
LoNDON
#7
ok i am trying to do some reaserch into this, does the reciver offer
a) embedded CAM.
:cool: separate CAM's
i am assuming by the looks of things it is :cool: but it does not state that or maybe i am reading it wrong ?
Likes
1,279
#8
It offers neither, but it may be capable of a software upload to decrypt some channels.
mrgentry
Likes
NONE
LoNDON
#9
having looked further it seems that their is no current upgrade but one was produced for a previous version so we can hope that one will come out for this.
thanks.
i shall now assume that free to air recivers cannot take cam,s
Topper
Amo Amas Amant Admin
Likes
3,244
IDD CI24 ECONO MM Penta 1.20 Galaxy II
1.2Mtr Polar MTG yes it has been on the arc for 25 years and is now fixed on 13 East using two pairs of rusty molegrips. Unlike me they never groan but always perform.
Blackburn, Lancashire
#10
FTA is just that free to air channels only.... no cams required. However some people are writing flash software patches for FTA receivers that allow decrytion of certain channels.
