linking up 2nd tv - help plz!!!!!!!
dukeraoul
pace box and big dish
portugal
Happy Xmas everyone! :-pachrist
Bought a tv for spare room, have run a cable from the back of my digibox 'rf out' thing to the new TV but it just says no signal - WHY?????
Thanks for your help.
rigsby
Echostar 3000ipVA on 1.1m dish motorised.
Sale
Hi.
You will need to select a channel that you don't use on your
2nd tv, then do a UHF scan as if you were searching for terrestial tv, this will pick up the frequency of the Satellite signal being sent through your cable & you should get a picture.
You may have to check your Digibox to make sure the RF out function
is set ON.
Cheers
dukeraoul
portugal
Got a picture but no sound! why on earth is that????
Perhaps your new TV is set for PAL B/G. Can you change to PAL I?
If you can't change your TV to accept Pal I transmissions then you might want to investigate buying a videosender. This would plug into one of the scart sockets on the digibox and the other unit plugs into a scart socket on the TV.
Another possibility is to use an old RF modulation unit off, say, a games console to send the TV signal down the TV aerial cable. Obviously you would have to get one with European Pal B/G capabilities rather than UK Pal I specification.
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
You could of course just get hold of your mums tv in the bedroom that hasn't been switched on for years next time you visit her:-tree Assuming of course she is still in the UK ... maybe not but you get the principle
The other option (if you have no PAL I setting on the TV) is to run it from your VCR and set the VCR to whatever AV connector the Sky runs into.:) The VCR doesn't need to be fully functional, as long as the loopthrough and RF modulator works.
