little advice DiSEqC 1.2 my settings
pothead13
Likes
Technomate 1500ci + 1000d super +
skystar 2 pci card
1M Motorised dish
Ivacon twin lnb
pc + laptop on network
uk
#1
hi im using your guides which are great but bit stuck not sure what these settings mean on my reciever
move <>
slow<>
position
reference position
east limits (ok flashes when click these)
west limits
delete limits
find satellite
another thing stuck with is the numbers on bracket (20-70) not sure what means and what should be on
im un south east uk if helps
thanks
Likes
1,279
#2
The first two are pretty self explanatory, moving East and West, the position i presume is to send the dish to a pre-saved position, reference point is normally zero, East and West limits are to stop your dish crashing into the wall, delete limits, self explanatory and find satellite is i presume for using USALS to drive to a satellite.
The degrees on the bracket of the dish are for elevation, the degrees on the motor bracket will be either elevation or lattitude.
pothead13
Likes
skystar 2 pci card
1M Motorised dish
Ivacon twin lnb
uk
#3
Latitude 51.806 Longitude-0.194 Elevation74 m
so whats what got bracket on dish 20-50and bracket on motor 20 - 70 very confused
Likes
1,279
#4
What make is the motor, I would advise that you add it to your profile, then you won't have to keep posting it. Some have a lattitude scale and an elevation scale, if it is a lattitude, then you put your lattitude, you will then need to calculate the dish elevation, called declination in motor setup, this calculation should be in the motor instructions.
pothead13
Likes
skystar 2 pci card
1M Motorised dish
Ivacon twin lnb
uk
#5
right i think im starting to understand my motor is DiSEqC 1.2
i checked my Latitude and is 51.788 my Elevation is 74m (is that what i set Motor Elevation Angle cos its only goes up to 70 )
and how do i know how set the dish angle (20-50)
and how do Point motor 0 degree to Truth South got compas not sure how use it
then i tune in to thor2 is that corret then go west to Hispasat then back again to adjust
im getting ther nearly
Likes
1,279
#6
No, the elevation referred to is the elevation of the satellite in the Sky and will be somewhere between 28 and 30 degrees, but that will not be what you adjust the dish scale to, as the motor armature has an offset angle.
Download the Calculator from www.smw.se and it will give you the elevation for 1W.
What does your motor instructions say the scale on the side represents?
pothead13
Likes
skystar 2 pci card
1M Motorised dish
Ivacon twin lnb
uk
#7
looks like getting sat man had enoth dont help when manaul in german
Likes
1,279
#8
What is the actual name of the motor?
pothead13
Likes
skystar 2 pci card
1M Motorised dish
Ivacon twin lnb
uk
#9
sateellite motor sm3d12
RedAltoGL
Now leaving, thanks all.
Likes
LNB, Dish, Motor, Cable, Receivers all taken down and donated to a newbie.
London
#10
Here is a link to download the manual in english
_http://www.sadoun.com/Sat/Order/Motors.htm
Just click on download installation manual for your motor.
regards Redmund
pothead13
Likes
skystar 2 pci card
1M Motorised dish
Ivacon twin lnb
uk
#11
thank you i got working set astra thor and hipasat all looking good
thank god
RedAltoGL
Likes
London
#12
Well done, it's a great feeling when everything falls into place, and you can get loads of extra channels without lining "Ruperts" pockets.
regards Redmund
phillpayne
Likes
humax 5400z patched to hot 11.1, v box mrk2, 1.1m triax dish, jeager 12&quot; activator .6 lnb, modified pet123 settings
kent
#13
hi pothead,
and now you have the taste of it, all you have to do is keep twiddling with it until you get the full 45e to 43w, thats when you crack out the booze
phil
