LNB & Feedhorn
Terryl
Likes
1,433
Custom built PC
#21
hey peeps, so the dish ive always had just has the normal LNB attached to it,
how do i use the LNBs ive got and how do i attach it to the feedhorn?
or do i need to buy a lnb specially for the feedhorn
i hope my question makes sense as im a newbie when it comes to feedhorn lnbs
What type of dish are you trying to add these LNB's to? A Ku band dish? Or a "C" band dish?
Likes
241
Dreambox 800HD SE, Dreambox 500S, Skybox F5S, 90cm Solid Dish, Tm2600 Motor, Inverto Black Ultra LNB! :)
Lost...
#22
ku band fibo gregorian
Likes
241
Lost...
#23
dont mean to sound thick but how do i disconnect the feedhorn and the existing LNB?
i think theres alloy key nut at the bottom which i think i need to undo to take it off
nelson_b
Contributor
Likes
1,408
Strong 4375 driving 1.8 C.M. offset + Inverto Black Ultra twin + BSC 421 and Zinwell C band l.n.b.,s - DR HD F15 - TM5302 and Skybox/Openbox M3 - HD receivers.+ other dishes in use - 2.4 CM offset - Alcoa 1.8 P.F. - C.M. 120.
north west yorkshire
#24
Hi -
Yes there is a hex allen screw at the bottom of the small hole on the side of the feedhorn ... its likely to be
seized / tight ... soak with wd40 or similar ... take care not to cause damage to hex screw or feedhorn
Likes
241
Lost...
#25
Hi -
alright kewl, i'll get some wd40 thanks mate :)
nelson_b
Contributor
Likes
1,408
#26
O.K .... yes dont rush it .. that feedhorn metal is quite soft and a bit thin near the screw .... they do get seized in the casting..... the hex key i use is 2.5mm (it may take one a fraction bigger) you may be lucky, if someone greased the screw last time it was out ... a couple of pics from my fibo 90 that may help. if it proves to be troublesome it may be easier to unbolt the 4 bolts holding the l.n.b. to the flange, and just bolt on a bought C120 . or a modified black ultra l.n.b.f.
Likes
241
Lost...
#27
View attachment 115786 View attachment 115787
yea i'll be careful when unscrewing it, thanks for the pics
Trust1
Likes
1,315
Nijmegen Netherlands
#30
Cut of the horn with my lathe , machine the OD of the waveguide at 25 mm .
That fits exactly in the Fibo horn .
Lnb in the picture is KOSCOM but almost any type can be modded .
