LNB Help - 23mm/25mm Collar in Europe
U
ukrv
kvh tracvision lf with pansat 3500sd - used on american motorhome in uk
somerset
Hi
We've just imported our American motorhome into the UK.
I was told we need to fit a European LNB, so removed the US one only to find the collar is just 23mm (could e 25mm) wide. All European ones Ive seen are 40mm.
Can I get a 23/25mm LNB in the UK ?
If not, does anyone do a bracket to fit a 40mm LNB to my system?
KVH have indicated I need a software/hardware upgrade too - costing £400 - but I want to try the LNB route first.
THANKS for your help !!
Paul
KVH Tracvision SF Auto Locating Dish with Pansat 3500SD Receiver
izefisherman
izefisherman
Ku: 2.4m Aerial PFA / Invacom SNF-031,
C: 1.2m Aerial PFA / MTI 15k,
DM7020-S, DM500S, C-Tech 2100, VBOXII
Finland
If you buy an angled MTI LNB (many other possible brands too) and split up the plastic housing (don't touch the white protective cap) you will have a cast-aluminium LNB with 23mm neck. Works fine!
