• This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn more.
LNB twist position
Mad Rat
Likes
65cm dish for Sky+ linked to all rooms, all with own remote and magic eye. Second box in home office (no multi room subscription just use card from main box if needed) 3rd box in bedroom Freeview in other rooms. Free cable in dining room Two 53cm mi
Leicestershire UK
#1
HI
I have fitted my new dish but need some help with the LNB, the Holder on the dish is marked from -20 to +20. what do I line the LNB up with? On the mini dish the markings are from 1-4 and I think its on 2 or 3.
Its for picking up Sky and I live in the East midlands.
2cvbloke
Bulbs need shelter too...
Likes
1,575
Near Pontop Pike, Co. Durham
#2
Just twist the LNB clockwise until you get the best signal quality on your box... :)
Mad Rat
Likes
Leicestershire UK
#3
Is that clockwise facing the dish or from behind the dish?
Also roughly what angle up wards should the dish be at?
2cvbloke
Likes
1,575
#4
Facing the dish from the LNB... :)
As for the dish's angle, erm, Ihaven't a clue myself but there are calculators out there, or you could use the old trial and error method... :)
Mad Rat
Likes
Leicestershire UK
#5
Thanks :-worship
2cvbloke
Likes
1,575
#6
Mad Rat
Likes
Leicestershire UK
#7
Just done a research on the internet, and the "up angle" (for the none technical) of the dish is between 20 and 30 degrees, the further south the higher. :)
2cvbloke
Likes
1,575
#8
That's the one, also known as Elevation... :D
Mad Rat
Likes
Leicestershire UK
#9
This is very useful info from,
_sam-radford.me.uk/index.htm
[fieldset=admin message]copied information removed
[/fieldset]
2cvbloke
Likes
1,575
#10
Cor, haven't heard his name for a while!!! :D
Likes
1,249
#11
There are hundreds of posts on this forum regarding best ways of aligning dishes, no need to copy from another site. http://www.satellites.co.uk/satellite/dish-setup-guides-stickies-faqs/ gives loads of information.
PS. The wet towel alignment method is pretty much outdated now, as most digital receivers have strength and quality metres for adjustment. It used to be effective in the days of analogue pictures, as after roughly aligning the dish to obtain a good picture, you could attenuate the signal enough to cause a sparkly picture, then adjust further to fine tune and regain a clear picture.
Mad Rat
Likes
Leicestershire UK
#12
Sorry but I couldnt find any that were as easy to understand.
