"LOAD ERROR" from dragonloader
ciaran
after setting to 6mhz using my multiprog ..... i then try to programme the dragon card loader using dragonloader.
although i am able to connect to the device, after a few seconds i get a pop-up message telling me that there has been a "Load Error".........
am i doing something wrong or could this be a hardware issue.
all the hardware is brand new.
help very much appreciated
dmm
try it a few times in succession - shouldnt keep repeating -
ciaran
have tried it loadsa times and it just keeps giving me the load error, even before any blue bars have appeared on the progress bar
loftyj
Hi m8
Have you downloaded both the dragonload drivers and dragon software
ciaran
i have the dragonloader software (simple application with connect and program?)......i didnt know that there were drivers for it as they were not mentioned anywhere.
i have drivers coming out of every orifice for this satellite stuff.....
hopefully this is what the problem is........can you possibly point me in the direction of them.
thanks very much in advance........
i was pulling my hair out
ormy1
not a silly anser but have you got a power supply on the programmer, I have a smartmouse programmer, but if it isn't supplied with 9V it fails to load. It will start but the blue bar will not increase. If this is the case and your using a smartmouse programmer you'll notice the RED LED go out after about 1 second of starting to download. This is because the serial port cannot power the programmer. I have a connector attached to a square 9V battery. Hope this is of help.
treeman2001
Echostar 36000
Phoenix infinity usb
Dragonloader
Sheffield
Hi there
After using the dragon cardloader successfully for about 8 months
I am also getting the same error message (load error) have you had any luck ?
Cheers
cjgall
Topfield 4000PVR with Aston 1.07 CAM, (canaldigitaal), dragoncam,
Sky digibox,
Bush HD Freesat,
Visiosat trisat looking at Astra1, Astra2 and Hotbird.
Netherlands & Central Brittany
Did you try downloading a differenct copy of preditor, this worked for me.
bazzar
great
engerland
it is possible that you have used your programmer to identify your loader card if so you have damaged it. but dont worry you need the dragon loader card repairer like you get with cas 3 interface software. this may fix you problem.
