loadepg 0.51 help!
T
totalacedude
Edit. 5620 several 500,'s (clones) vu duo blackhole pc server 95cms motorised dish blah blahh
crewe
hi guys
can any 1 pls help me with installing and using loadepg.
i am using a 800 clone and gemini and want to try using loadepg, but i cant find anywhere any decent info on how to setup etc!
im only just getting the hang of the linux way so i might be asking a few times lol
ive downloaded using blue button, but i believe you have to configure it and edit a cron to run it at a time of day, but in the db i dont really have a clue atm, ie where and what to edit etc!
so any help about setting it up or even help with files i may need would be appriciated
cheers guys!
ian
B16MCC
B16MCC
Dreambox Gimp & Coder
2 Dreamboxes..........
--- DM 8000 HD PVR & DM 800 HD ---
Motek SG2100 & Triax 80cm Dual LNB
------ Fixed Dish 28e Quad LNB -------
---- Sly HD Full & 24" Apple iMAC ----
/var/tuxbox/config
I can't help with this plugin I'm afraid , but can I ask is there any reason you're using Gemini ?
If you switch to Nabilo blackhole 0.12 you'll have the best available EPG built in and dead easy to use.
T
totalacedude
crewe
no reason for using gemini just what came with the box!
ive just got the knowlage to bugger about with it as yet!
bought as a genuine turned out to be a clone so am bit afraid of what to put on it!
is blackhole clone safe? do i just flash using dreamup and final thing i can think of.
is there still a plugin download button for things like cccam etc (like gemini)
if so i think ill be taking up the advice :)
cheers ian
B16MCC
B16MCC
/var/tuxbox/config
If its connected to your router flash it using the web interface. Tutorial in the 800 forum. The only unsafe clone image is Gemini, nabilo will be fine and Yes it has an addons panel.
T
totalacedude
crewe
tar very much!
i think i know what ill be doing over the weekend now :)
is it specifically Nabilo blackhole 0.12 i have to get? or is there other versions?
time to backup my channel list and sat positions :)
is there anything i need to be aware of before / during flashing
ie anything more than back up channels, and make a note of my sat positioner stored positions that i need to do before i start flashing #
the only flashing experience i have is my old 5620 when i had a power cut and it went tits up!
cheers ian
B16MCC
B16MCC
/var/tuxbox/config
Blackhole 0.12 Is the latest Enigma 2 image from Nabilosat for the 800/8000 boxes. Always use the latest version.
Backup the obvious , softcam config files if you use them.
/etc/CCcam.cfg
/etc/CCcam.channelinfo
/etc/CCcam.providers
/var/tuxbox/config/newcs.xml
Picons, if you use them, if they're in flash.
Bouquets obviously, back em up with DreamboxEdit.
Now as for sat positions, that totally depends on your setup. If you're using a Diseqc motor then I highly recommend using USALS, set the tuner config to , Simple & Motor. Then enter your lat and long from google earth. Job done, no sat positions needed.
shumifan50
shumifan50
2xDM7025(DVB-S tuner), DM600SPVR, DM800S, DM500S HD, Triax 90cm with MultiBracket 4 sats.
Europe
The EPG on Nabilo is great with some caveats: I have now had many crashes and looking at the crashlogs it is always somewhere in the EPG code, when it is manipulating the EPG data files. The plugin to save the EPG across boots does not seem to work. I have downloaded and installed it and still lose the EPG across boots.
At least the e2_loadepg software retains the EPG across boots and does not cause crashes anywhere near as much as NB12 EPG does.
So it is swing and roundabouts. You makes your pick and .....
shumifan50
shumifan50
Europe
B16MCC
B16MCC
/var/tuxbox/config
Interesting info mate. I have had no such problems on either of my 8000 or 800.
B16MCC
B16MCC
/var/tuxbox/config
T
totalacedude
crewe
lol just as i decide to go for blackhole
i get smaked in the face with this nugget of info lolol
feel like a kid in a candy shop decideing what to do....:)
fanx for the input tho guys!
T
totalacedude
crewe
M
marcaaron20
Dreaming Satellites
Dreambox 8000 HD,
80cm Orbital Satellite Dish
Motorized
LNB with 2 outputs, 2nd output leading to upstairs and using Dreambox 500S.
Pioneer VSX-1018AH-K Amp/Receiver,
Stockton-on-Tees, Cleveland
I need the file Sky-ITA for this so it can update the sky italia's epg, I have got the Sky-UK file, my mate sent me it
This is the 1 for Dreambox 8000 and using Blackhole 0.12
M
marcaaron20
Dreaming Satellites
Dreambox 8000 HD,
Motorized
T
tomthebomb1968
VU+ Duo 250gig/ DreamElite BH 1.3.2 Multiboot
Dreambox 500s-(clone) / DM-600
Relook 400s 160 Gig-/SifTeam 1.93 e enigma
Foretec 90cm Dish with Nikkai Diseqc Motor- 2 sky+ receivers fixed 28.2 east.
Newtownabbey, near Belfast, Northern Ireland
Why cant you download it straight to your box?
T
tomthebomb1968
M
marcaaron20
Dreaming Satellites
Dreambox 8000 HD,
Motorized
I've tried that, doesn't work, the file is missing or something cos the box just crashes and then restarts , like with the SKY-UK so my mate sent me a file called channels.uk so I added that via ftp to the correct folder on the dreambox 8000 and the epg updated straight away after that
i need to do the same for Sky-UK now, there should be a file named similar, eg. channels.ita
also my mate also said to not use the satmate ones cos it sometimes misses letters out of the programme names or something which is annoying at times
M
marcaaron20
Dreaming Satellites
Dreambox 8000 HD,
Motorized
T
tomthebomb1968
I also had some trouble with the plugin I was told to download the _EPG AutoSave_nab.tgz
I done a manual install and it works fine now when I run it from the script menu.
T
tomthebomb1968
