marcaaron20
Dreaming Satellites
- Jun 12, 2005
- Age
- 39
Dreambox 8000 HD,
80cm Orbital Satellite Dish
Motorized
LNB with 2 outputs, 2nd output leading to upstairs and using Dreambox 500S.
Pioneer VSX-1018AH-K Amp/Receiver,
- Stockton-on-Tees, Cleveland
marcaaron20 said:I've tried that, doesn't work, the file is missing or something cos the box just crashes and then restarts , like with the SKY-UK so my mate sent me a file called channels.uk so I added that via ftp to the correct folder on the dreambox 8000 and the epg updated straight away after that
i need to do the same for Sky-ita now, there should be a file named similar, eg. channels.ita
also my mate also said to not use the satmate ones cos it sometimes misses letters out of the programme names or something which is annoying at times
any help tomthebomb1968??
thought you were top guys when it came to the Dreambox, I'm just a learner so far
Thanks,
I'll need to sort it by the weekend cos I plan to install Window 7 tomorrow night so I will imagine my computer being out of use for a couple hours whilst I save me files, install Windows 7 and get my software/hardware installed back on then to get back online
