Manhattan 5500 CI_M problem
dooleytoole
Hi , Im new to this game and need some help.I have just acquired the mentioned receiver and had it set up.It has Conax embedded and was working fine,I unplugged it so I could finish placing the wire around the house.When I plugged it back in the red standby light came on and the 4 dashes where the channel number should be ...and thats it.Nothing happens after that.Can anyone help sort this or give some pointers??
Thanks in advance!!
I doubt it has embedded Conax (but Im ready to refute that )
They were originally released with Irdeto and S*ca only.
What does the installer tell you ?
dooleytoole
As I said Im new to this game ... it definitely has Conax in built...was watching canal+ on 1 degree west and a few other channels before I decided to finish off fitting the cable as I said.As for the installer ?? the only other info I can tell you is I am using an M2 card,my mate set it up for me and he is trying to find out why it has gone to this state ..but he isnt online at the moment!!
Thanks for your quick reply
