We are facing problems with skymate sk3000 dsl receiver as it repeatedly asks to insert smart card )(-red or shows channel scrambled 'O'-red. just yesterday we took it to the seller and had it re-tuned by paying a big amount and the seller said i will work without problems for 6 months. Please advise what should we do as its really frustrating.. THANKS
Hello everyone! I have a receiver with the interesting name: "Orange". Everything worked fine until I accident don't blocked PIN. So tell please, if somebody knows, master PIN or model of the tuner firmware from which would fit.
hi masood and freinds
i have bought a second hand reciever
HISAT 2C1 0 GB SAT
IT HAS A PIN AT START UP HOW TO REMOVE THIS OR ANYWAY OF HARD RESETING?
THANKS
I have a second hand HISAT 2C1 0 GB SAT receiver.
It was setup by a Sat Engineer along time ago and I have never needed to change anything, however now the Thai TGN channel has moved to another frequency so I need to modify the receiver settings but I do not know the password. I have made a number of attempts but nothing has worked. Can anyone advise on what the default password should be or know how I might reset it or a way to by-pass it?
Regards
Karl
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
