matrix problem
freddeifk
i just bought a matrix reloaded cam , i have a samsung 9500
but the cam is not initzialed
and i have tried too turn that reciver on and off O-Ha but no success
what too do.
Have you tried changing slots? Also pulling the CAM out and replacing?
Some people have more luck by firing up the receiver when on a non-encrypted channel.
Also where did you get it from, some are delivered without software.
freddeifk
tryad all that,
but maybe mine is without software.
if it is ,how can i programm it with software.
You need a CAS interface or laptop, won't be able to do it with the funcards if your receiver doesn't recognize it.
Razor
Retired Mod
Ireland
Or send it to the DEN and have the latest files loaded....£15 + p&p.
If you do not have a CAS this is the best option.
Don't think they are doing that any more Razor, too many people sending in fried CAMs and then expecting a replacement when it doesn't load.
