monoblock 10 and 16 degrees
M
moosegoose
bog standard
Likes
80 cm dish hh motor teco tm1000 dreambox 7020
cas 3interface
dragon cam.promax tv explorer 2.
norwich
#1
hi wanted to get some romainia fta stuff from eutelsat w2 10 and 16 degrees will a monoblock and 80cm dish do im based in norfolk.according to lyngsat it looks ok but as i never tried it so i thought i just check.thanks in advance.
Lancelot
Lancelot
Retired Mod
Likes
SS1.
36v H to H 62E - 61.5W
South central
#2
Depends on the transponder(s) you're after there. Both 10E and 16E can be a bit of a struggle at times especially in wet weather.
Go for it is the answer, but remember to set the centre LNB on the dish to the weaker transponder/satellite that you need,
Rgds
L.:)
B
bigtee
Likes
Sky; Raven 90 multi-LNB 1W,5E, 7E, 9E, 13E 16E, 19E, 28E; 60cm Triax dish on Moteck SG2100 motor; Various Receivers
Kent, UK
#3
Also, if you haven't bought the monoblock yet, consider using two separate LNBs instead --- though that would then require a diseqc switch.
Le Basseur
Le Basseur
Likes
Old 1.2 m Andrews Channel Master dish,MTI Supreme Line Universal Twin,Axing SKB95-01 cables,Nokia Mediamaster 9800S,Pace MSP991 positioner
Croatia @ 45:33:33:86 North 18:40:03:85 East
#4
Hi Moosegoose,
Take a look here:
http://www.satcodx1.com/0100/eng/
As you can see,the Eutelsat W1 at 10,0 East doesn't carry ANY Romanian TV prog.However,there used to be some "Romanian stuff" on this satellite but AFAIK,they're moved a long time ago.
Actually,the best way to get Romanian FTA's is to have a motorised system instead of a fixed dish w. monoblock/dual LNB combination.This way,you might be able sweeping between Amos and Intelsat 902.
HTH!
Regards,
P
Park Royal
Likes
Smart lnb, 1m Gibby dish, Stab motor, TM5200D receiver, 57east to 61west. DTT from Sudbury. Virgin Media broadband.
So called capital of Suffolk, UK.
#5
Here is a list of where the Romanian channels can be located
_http://www.flysat.com/tv-ro.php
Parky
Le Basseur
Le Basseur
Likes
#6
Hi Parky,
This is what I was talking about...the link you posted contains some outdated Romanian FTA transponders (I have myself several similar links but I gave up watching them for obvious reasons...they update too slowO-zzz).
For instance,as I already said,the W1 @ 10 East @ 11131 V doesn't have anything Romanian.The "Antena" package moved on W2 @13 East.
Anyway....if you want correct info,watch for lyngsat or either satco.
Regards,
Topper
Topper
Amo Amas Amant Admin
Likes
3,365
IDD CI24 ECONO MM Penta 1.20 Galaxy II
1.2Mtr Polar MTG yes it has been on the arc for 25 years and is now fixed on 13 East using two pairs of rusty molegrips. Unlike me they never groan but always perform.
Blackburn, Lancashire
#7
Just to avoid further confusion W2 which does have the Antena Package is actually at 16 East
Le Basseur
Le Basseur
Likes
#8
Yep,my mistake! :-slaphead:-slaphead:-slaphead
Thanks Topper!
Regards,
