monoblock & motor
casper22
force d-master 1122s
88cm triac dish with twin output monoblock for astra+hotbird + technomate tm-7755
workington , cumbria
I HAVE A FORCE 1122S AND A TECHNOMATE TM-7755 ON A TRIAX DISH WITH A TWIN OUTPUT MONOBLOCK LNB. HOW DO I RUN A JAEGER DG-120 H-H MOTOR OFF THIS AND MY MONOBLOCK THROUGH A DISEQC SWITCH ON MY TECHNOMATE RECEIVER. IS THIS POSSIBLE ? :-sball
It will need to be the type of monoblock which mounts on one side, then you can set up as normal, but you will of course only be able to use the offset side for Astra when you are pointing at Hotbird with the main receiver.
PS. Caps Lock Stuck?
