Motec SG2100 motor for a 1m dish?
harrowwoman
Harrow, Middlesex
One dish 1.5cm with 3 LNBs picking up Hotbird,Arabsat,Astra
old Echostar receiver, GlobalStar 6000i
Harrow,Middlesex, UK
Would anyone here recommend a Motec SG2100 motor for a 1m dish? I heard its dead easy to install, I have a fixed dish at the moment but am toying with the idea of motorising to get more from my little ol Silvercrest SL65, I might even get the Echostar out of the cupboard under the stairs where I stashed it in disgust as I could not understand how the programming worked. Mind you-I am not much better off with this receiver, it still has me stumped.
I did a scan recently and ended up with something called New Satelite of which I am highly suspicious, think it might be Hotbird masquerading under another name! Here are the various bits of info, hope they make sense to someone.
LNB Freq 9750 10600
Trans Freq 11429
Symbol rate 27491
Then I have Hotbird 13E which gives me (according to the receiver)
LNB 9750 1060
Trans Freq 11582
symbol rate 27492
There also seems to be a Sirius 5.0E
LNB 9750 1060
Trans freq 11728
Help!!
jimbo
Retired Mod
Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
Greater London
You asked about an installer in another post, did you see my reply?
intrepi
Viewsat Ultra, Stab MP 02 DiSEqC 1.0 to 1.2 code convertor for Stab HH 120 motor drive, Winegard 1 meter dish with an Invacom quad LNB
British Columbia Canada
The SG 2100 motor or the Stab HH 100 or Stab HH 120 motors will all handle your 1 meter dish. Before you decide, you may want to check what DiSEqC code your receiver is transmitting as there are different code versions called communication Protocol version 1.0 1.1 1.2 and I believe a 1.3 Many receivers use 1.0 which is fine for the LNB but for motor drives many require 1.2 to operate correctly. The Stab MP 02 is an inline convertor which will take the 1.0 code from a receiver and change it to 1.2 code then send it to the motor drive. This is very important as your receiver has to send the correct code to the motor or you will develop problems with the motor drive.
This switch is easy to find using a Google search for Stab MP 02 and it is very easy to install so be informed before installing or using a motor drive with any receiver.
The receiver concerned is well equipped to use the necessary Diseqc protocols to drive a motorised dish, so no external switch is needed.
Yes and in fact, very few current receivers do not have DiseqC 1.2.
harrowwoman
Harrow, Middlesex
I did Jimbo thanks, I will see if I can get someone to help me install the moror, looks fairly straightforward. If you dont try you wont know if you can do it!:)
