moteck motor
Likes
sky etc
ireland
#1
HI
I am trying to setup my dish and motor . I am using a triax dvb 262 and a moteck motor mount I may have some of the angles incorrect my latitude is 52.258 .I can move the dish to hotbird and astra 1 but I can find anything else
I need help
vinsat:-bigsanta
Likes
1,287
#2
What is your longitude?
mhku
Likes
20
TM Nano ~ sg2100
Midlands
#4
Welcome to the forum!
I can't help you with your receiver but:
is the pole true? Did you set it all up from your southerly most satellite and work from there- needed to get the arc correct?
Likes
1,287
#5
Try setting your dish on 5W, there is a good transponder with French digital channels 11591 Vertical http://www.lyngsat.com/ab3.html.
Once found you can fine tune by slightly offsetting the motor by a couple of degrees East and realigning to it. You should then be pretty much on the correct arc.
Likes
1,287
#8
Well your motor bracket setting should be your lattitude on the Moteck, your dish declination setting should be as per the calculation in the motor handbook. If you have an old analogue receiver, you can find the 5W satellite quite easily, as there are still a few analogue channels on there.
Likes
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up
cheshire,algeria
#10
give us your exact location (nearest town)
Likes
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
cheshire,algeria
#12
if your setting up for 5w, your angles should be something like below
( hopefully one of the senior members will confirm this)
all you need is a spirit level and protractor, set the angle and slowly sweep back and forth towards the sat
good luck
Likes
sky etc
ireland
#13
thanks bronking and rolfw
I will set this declination angle .I lost the motor handbook (SG 2100A) model SO I have no idea for the declination setting I have already surfed the net for a copy if anyone can pass one on I would be greatful
and hopefully I will have a happy christmas
gerryl
Likes
good luck
luv the Pic whats the URL or will ye do one for Belfast South...setting up in 2006, got the motor but need some time off to fix...
Belfast South- Lat: 54.550 Long: -5.900
http://www.heavens-above.com/Neighbours.asp?PlaceID=523751&lat=0&lng=0&alt=0&loc=Unspecified&TZ=CET
thanks for any assistance..:-sball
Likes
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
cheshire,algeria
#16
don't forget your setting this for 5w
