Help Required Motorized Dish & RF Modulator Quality 0% Help
530112
Openbox S10 and X5
Thailand
Hey Guys so here is my setup:
I have a motorized satellite with openbox s10 in the bedroom where I can watch FTA and KU channels.
There is an RF Modulator connected to the received and then to the wall so I can watch downstairs on the other receiver (openbox x5).
All FTA satellites I can watch downstairs, but for KU I can't even scan channels because I get 70% signal but 0% Quality on all transponders. Upstairs in the bedroom working fine.
Any idea why?
Thanks in advance.
Hello & welcome to the forum
How is the second box connected to the dish - does it have its own feed from the dish or have you split the lead to the first box?
EDIT - ah having re read your post the problem is in the link. Remove the link and give the other box its own feed from the dish.
Costactc
Canada
If your signal quality is strong on the one receiver then I have to agree that your probably double switching for the second unit. I'm definitely not a switch expert but I do know that you can't switch out a feed that is already on a switch.
530112
Openbox S10 and X5
Thailand
Thank you for your replies.
But the thing is All FTA satellites are showing good signal and quality on both boxes, there is this only one Satellite Measat KU with c-line that shows no Quality on the second box, working fine on the first box.
Do you think its something with the LNB frequecies settings?
Well we cant help with ANY problems related to your c-line. Such discussions are absolutely forbidden on this forum.
