Motorized Sky Dish
mkdons73
TM-3300 2CA, 85CM Dish, Monoblock 0.2dB LNB
Milton Keynes
Hi
Is it possible to motorize a standered sky dish , i.e just purchase a motor instead of dish and motor.
Cheers
Mark
Yes it is, but you will be limited on channel reception, as it will be too small for reasonable reception on many of the satellites in the available arc. For your location, an 85cm would be a better bet.
Also the minidish requires a bit of modification for permanent attachment to a DiseqC motor, as the LNB is pre-skewed and unless you want it sat off to the side, you will need to adapt the elevation bracket or make a new one.
Here is
a zone 2 minidish on a motor. :)
mkdons73
Milton Keynes
Thank you rolfw,
Think i may opt for purchasing a new dish with motor in this case, any recomendations?.
I have just purchased a TECHNOMATE TM 5400 CI+ USB, so maybe something that is compatable with this reciever.
Cheers
Mark
Get yourself a Fracarro Penta 85cm Aluminium dish, one of our supporting advertisers sells them, the outperform most other dishes of that size. Motor wise, the popular Moteck SG-2100 is a good bet. :)
mkdons73
Milton Keynes
Well seems i got the reciever wrong , its infact a 3400 D+ , no USB so patching will be via cable , what cable is needed , this isn't a problem as i have a couple of laptops i can take to the unit .
Cheers
Mark
A Null Modem cable for flashing. :)
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
Cheers
Mark
And a serial port on the laptop. Most laptops don't have them, so you might need a USB-RS232 adapter, which can be tricky to get working sometimes.
Always a good reason for keeping hold of your old lappy. :)
