My new dish and motor.
bobon
Kaon,Vantage,azbox plus,spiderbox 9000
receivers.Vbox, CM 1.2 dish,
1224HH mount,c120 lnb
with CM feedhorn.
Manchester, England
Recently bought a channel master 1.2 mtr dish and a 1224 h-h motor.After many hours trying to set up, i finally managed to get a signal on thor, it did'nt help that the instructions gave misleading advice but once i moved away from the said instructions it finally came together. So here are some pics.
staffspeted
Channel Master 1.2 driven by Supermount SMR 1224 mount.
V-Box 11
Triple Dragon Linux Receiver.
Vantage VT-X221TSCI Blindscan Receiver.
Diablo Wireless cam and base.
42" Panasonic Plasma.
50" Pioneer Kuro Plasma
Lots of boys toys!
Herts , UK
Great set up , just like mine but a different colour!
Whats your location? What sats can you see?
Regards Pete
dasteelman
85cm transparent dish
85cm Penta Dish (motored)
Black Ultra LNB
VU+Solo
VU+Duo
technomate 9100 linux
Quali-TV (4:2:2)
Eaglebox
UK nds card
Tyne and Wear
nice....isnt the hedge causing you any problems on fringe satellites?
bobon
with CM feedhorn.
Manchester, England
Not fully installed yet, only gone as far east as 26d and 12d west (need more time but wife keeps finding me things to do) .The hedge may be a problem the further East i go, but could get 42e with my old setup, also could get a couple of sats further west of hispasat before. Location Manchester area.
CROSSBONES
S.Wales
Nice set up. It would be worth you getting the correct feed horn for your dish. It will improve the weaker sats.(not saying that that is your main problem)
I would say the hedge shouldn't be a problem;)
wod
yorkshire
nice just swap the lnb for the c120 invacom and channel master feedhorn than your sorted
tomhagg
TECHNOMATE
SCOTLAND
very neat pics make looks good.;)
bobon
with CM feedhorn.
Manchester, England
took advice and bought the CM feedhorn and a invacom lnb, results were not brilliant but a definate improvement.Heres a few pics, notice the break on the plastic lnb holder? i decided to squirt a little wd40 on the rusty screws and i heard a pop about 30 seconds later, so dont ever do that.lucky for me a new one came with the feedhorn. I have a question, why does the top of the plastic lnb holder have a sort of bridge across the arch? it stops the spacer from sitting properly if you can understand, can you notice it on the picture?
tomhagg
TECHNOMATE
SCOTLAND
nice setup mate ,the hedge could be a prob and there again maybe not.
