My Theatre problem
paddy22
Likes
Hi I've been using MT quite happly for 2 months, but I've had to format the Pcs harddrive, now when I've re-installed MT I'm unable to view encrypted channels.
I have Yankse 1-22-2 common files and the yankse 1-22-3-tt and the latest softc*m key from cardmania yet the sod won't decrypt, can anyone give me the correct instructions for where these files are supposed to go cos I must be missing something. sorry for being such a pratt, but it's doing my head in.
thanks for any reply
BGonaSTICK
Likes
Dreambox 7000, Skystar2
Brighton
#2
My recomendation would be to use the new S2emu.dll V1.04 (in 'MDPlugins') and the latest Mach1 s0ftkey (in MyTeatre root dir) both available on TCD.
The only other thing you will need is the MDWrapper.dll (automatically placed in 'Plugins') that comes with MT2.76 if you select it as an install option.
Will open S*ca S2 (Sly Italy) and C*nax when we get the new keys (worked with last weeks C*nax keys 'till they changed yesterday).
You then won't need Y*nkse. The version you quote is very old now anyhow.
paddy22
Likes
Hi I've done as u said and everything is in place, no picture! I'm on Thor and nothing is showing, I thought I had the latest softc*m key, got it this morning using the key downloader, has a working one been issued or are we still waiting and could it be the one I've been using is a dud.
thanks for the heads up on the s2emu1 I downloaded it last night so I could try it out, so it was handy.
thanks for the help
BGonaSTICK
Likes
Brighton
#4
New C*nax keys not available yet.
S2 on 13E is though, and S2emu is the only PC plugin that can open it!
paddy22
Likes
LoL ! so I've been loosing the little hair I have and the softc*am I've been using has not got the right k*ys in for C*nax! I deserve to be bald. big thanks I'll try 13 east while I wait for C*nax and the hair to grow back.
Cheers
paddy22
Likes
Has the C*nax keys been updated in the softc*ms yet, their seems to be plenty about but none seem to give up the Kiosk or C*nel channels on thor. I don't know if it's my set up, or the keys I'm using, can anyone advise,
cheers
