need a bit of help pls folks
lee32uk
Likes
Technomate 1500ci+ super
Triax 1.1m dish
Diseqc motor
Invacom lnb
Manchester
#1
hi all
well ive had my dreambox for 3/4 days now and im struggling a little bit decoding channels.
I had flashed a new image to the box (Hydra 7000 olympia xxx) and can manage to get the card slot to work ok with a via2 card, but no pay channels clear.
My box is only connected via a null modem cable at the moment until i get a network card, so is this the problem ? do i need to update the keys before it will work ?
thx for any help :D
Lee
Likes
1,287
#2
Yes I think you do Lee, most images come devoid of keys and you need to update by FTP. I'm not sure whether it is possible via Com port.
BGonaSTICK
Likes
Dreambox 7000, Skystar2
Brighton
#3
What can't you get to clear, the VIA2 encrypted channels or something else?
I take it you have an official VIA2 card... for what bouquet?
You're using it in the card slots, and not in a CAM?
You can get al FTA channels? Can you get ANY encrypted channels?
Have you loaded any keys?
LOL, I have more questions than you!
lee32uk
Likes
Triax 1.1m dish
Diseqc motor
Invacom lnb
Manchester
#4
I am using the via2 card in the top card slot...card is for sv+ ;)
Havent loaded any keys as the box is only connected via a serial (null) cable at the minute.Do any images come with keys pre-installed ?
I get fta channels ok and thats about it
Need to get myself a network card quick lol
T_G
The Consumate Dreamer
Likes
212
1 GigaBlue Quad plus, 1 Dreambox 5620, MOTECK SG2100A DISEqC Motor, 120 cm noname offset dish, Humax 95 cm offset dish and a few UK digiboxes.
Somewhere where the Sauer is Kraut and the Wurst is Brat
#5
There are some images that come ready to go, but sooner or later you are going to have to update your keys...So best is to get your network set up....
BGonaSTICK
Likes
Brighton
#6
lee32uk said:
I am using the via2 card in the top card slot...card is for sv+l
Are you saying that you can watch SV+ (by using your card) but that you can't open anything else that requires keys?
lee32uk
Likes
Triax 1.1m dish
Diseqc motor
Invacom lnb
Manchester
#7
Couldnt get anything to open using Hydra image.......BUT ive put RUCannon 5 on and im managing to clear Sky Italia package, Freextv and Taquilla on 19e so im doing something right :D Not really sure what im doing yet but im still learning ;)
Anyway im gonna pop into pcworld tommorow and get a network card so i can have a proper play around with the box :p Up to now i still have a full head of hair lol
P.S Are there any free ftp programs available ? Dont mind buying one but just wondered
Thx
Lee
BGonaSTICK
Likes
Brighton
#8
Nice one. Make sure you get your Cat5 crossover cable while you're there.
It's NOT the same as an ordinary cat5 patch lead. Even PC World should know the difference :rolleyes:
As for an FTP client, you can't do much better than WS_FTP Pro. If you want it for nowt, type 'FOSI' into google, and go to the top entry. You'll find it there. :)
Let us know how you get on with rucannon 5, 'cos I like what I've heard about it! ;)
lee32uk
Likes
Triax 1.1m dish
Diseqc motor
Invacom lnb
Manchester
#9
hi its me again ;)
well ive got my network card installed ok and all seems well.Just downloaded rsakeylist file from toes and now ive got conax too :)
RUcannon 5 seems a good image so im gonna stick with it for a while till i get bored
everything seems to be clearing ok.Wish i would have bought a dreambox months ago :D
Likes
1,287
#10
LOL, easy as that Lee, feel the same myself, got the Black tiger working and will stick with it for a while. :)
BGonaSTICK
Likes
Brighton
#11
Yes Way!
WE ROCK!
O-HaO-HaO-HaO-HaO-HaO-HaO-HaO-HaO-HaO-HaO-HaO-HaO-HaO-HaO-HaO-HaO-HaO-HaO-HaO-HaO-HaO-Ha
MacAddict
Likes
lee32uk said:
hi its me again ;)
I liked ruCannon5 a lot, but could not get the multi view EPG to work on it :(
