need help for dreambox 500s
Msari1974
DreamBox 500s
US
Can’t even get dreamup started can someone please help me. I have read the instructions over & over. I have the right cable & I think I have the right dreamup, but when I run the dreamup it jest gives me the same Connection prepared, now switch dream box on. Can someone tell me how long it takes for it to start running or if I need some other software to convert Linux to Windows. Any help will be really appreciated.
dig deep
Prince of Birthdays
Dream7020 and AZ Elite and a few DM800
Sweden
It should start almost instantly.
I suggest that U do it from the beginning by removing the power line completly and let it be that way for a 5-10 mins.
Then U start dream-up and when told attach the power line again
You say you think you have the right cable, which cable have you got?
tomthebomb1968
VU+ Duo 250gig/ DreamElite BH 1.3.2 Multiboot
Dreambox 500s-(clone) / DM-600
Relook 400s 160 Gig-/SifTeam 1.93 e enigma
Foretec 90cm Dish with Nikkai Diseqc Motor- 2 sky+ receivers fixed 28.2 east.
Newtownabbey, near Belfast, Northern Ireland
if nothing happens on com port 1 try com port 2
Msari1974
DreamBox 500s
US
I had serial cable instead of a null modem cable. I cut the wires and rewired them like the manual said. Now I am in the next step. How can I get the channel list for Dish and Also What .img is the best because I can not install emu_manager.tar.gz to the gemini. And the key. Can somone help.
