RedDevil_UK
Retired Mod
- Sep 24, 2004
- Age
- 54
- Dreambox 7000S, VU+ Solo2, 1.1m Dish, Moteck SG-2100A DISEQC Motor
- Rochdale
i had my DB installed last weekend, and couldnt get any channels
so after a bit of advice of you guys i decided to flash with an image... i went for hydra lucien and everything seemed to work OK. I did make a note of all the motor settings before hand, and put them all back in after flashing?
my dish is now pointing to East?? about 5 Degrees i think..... and its stuck!
no matter what setting i use it wont move, gotoXX or motor power?
