- Jan 1, 2000
- Age
- 58
- 1 GigaBlue Quad plus, 1 Dreambox 5620, MOTECK SG2100A DISEqC Motor, 120 cm noname offset dish, Humax 95 cm offset dish and a few UK digiboxes.
- Somewhere where the Sauer is Kraut and the Wurst is Brat
RedDevil_UK said:thing is, it was fitted by pro's
i paid them £150 cos they knew what they was doing???
well it goes left and right on the search now.... but can i lock onto satellite... NO!!!
how the hell do you find em?
do you have to do one step at a time, or can you just move west till the signal rises then fine tune
ive tried finding HOTBIRD, EUROBIRD and ASTRA to no avail yet
Well, if you haven't moved the motor and had reception previously you should be ok. Have a look at the following thread,
http://www.satellites.co.uk/php-bin/forum/showthread.php?t=29530 , it deals with all the go to xx subject, including various tips. Generally your box should be able to find the sats on its own, but that is more often than not a bit problematic. Finding the sats and storing manually is probably the easiest solution.
Finding the sats should not be too hard, it is well worth setting a strong transponder (see idiot guide for a link to a list of those) and then slowly moving the dish. It should not be too hard finding strong ones like 19 east, 28 east or 13 east, especially if you got anopther satellite dish you can see. Then you can get some sort of idea where to look.
