- Likes
- 0
AthonX 3700+ CPU
ABIT KN8-SLI MB
PNY Geforce 7800GT GPU
SkyStar 2 PCI card
80cm Satellite Dish
- Bath, United Kingdom
My uncertainty is divided into three main parts:
1) I have just setup up my 80cm dish and SS2 card and got signal of about 30% -> 60% quality. Is this normal? Also, my signal bar sometimes keep going off and on again. Is this due to wind or bad connections?
2) I am locked onto astra 19.5E, does it include all the astra transponders i.e. astra 2A, 2B, 1C...etc. so when I scan using progDVB I scan all possible astra?
3) I am a football addict and I really want to know which channels in astra have live football matches... like premiership and la liga(barca). If they are encrypted can you tell me what is the best way to decrypt these channels?
I will be greatful for any help you can give me.
Any amount of advice is welcome!
Cheers~
Moved to this section as it may get more response - Admin
Cheers~
