Need help VERY Quick
Z
ziko
Hi
I need quick answer
I want to buy dig.receiver, and I can make up my mind between
NOKIA 9800 S - embedded Viaccess or
Echostar AD 3000 IP - embedded Viaccess
Which one is better with pirate card (viaccess and Seca)
Quick answer PLEASE
2old4this
Honorary Admin
Cloud Cuckoo Land
[font size="1" color="#FF0000"]LAST EDITED ON 11-Jan-01 AT 08:16 PM (GMT)[/font][p]Strange comparison...
The Nokia 9800 has no analogue and no built-in positioner. The Echostar ad3000ipva does. So you are comparing apples with pears.
If you require analogue and a built in positioner then the Nokia will simply not do the job (however good it is as a machine)
On the other hand, if you don't require those features, why pay for them in the ad3000ipva? There is a perfectly good digital CI viaccess Echostar receiver without the analogue & positioner - it is the "DSB-2110 2Ci Viaccess" (in fact, it even has 2 CI slots compared to Nokia's single slot).
http://www.echostar.nl/download/manuels/DSB-21102CIViaccess0609En.pdf
So do you need analogue & positioner or not...?
2old
Z
ziko
I don't need analog but I do need positioner.
DSB-2110 2Ci Viaccess is older than Echostar 3000 isn't it, and is it better to buy older model ?
2old4this
Honorary Admin
Cloud Cuckoo Land
Actually it's a brand new model. Not all dealers are stocking it yet.
If you need a proper positioner (as opposed to DiSEqC) and you need it to be built-in, then the Nokia 9800 is no good.
Other digital+positioner+viaccess modesl include the d2510 viaccess from Echostar.
http://www.echostar.nl/download/manuels/D-2510IPViaccess0714En.pdf
But there are more.
I suggest you spend a few weeks checking out what is available and what the differences in the features are, otherwise it sounds like you'll be buying the wrong one...
And check out this source of info:
http://www.ilgradio.com/satworld/
2old
