Need help with Dyson
Yeshi
Yeshi
Dm500, TM9100, Samsung V+, 1M Dish. Motect 2100..
37Inch Plasma, Wii, Xbox360.
Behind pin 9 on an atmel
Hello.
I have a dyson vacum which is the alergy one.. for the past few weeks its struggled to pic up any dirt,.. infact to get it to pic up dirt i have to put presure on the base..
They say theres no loss of suction but this takes the biscuit..
any help???
-www.satvacs.co.uuk :-rofl2
Bagless vacuum cleaners have to have filters to stop the fine dust returning to the atmosphere and these need cleaning. There are usully several to check - a cheap bagless from Asda I looked at had 5 separate filters to clean!
Eventually the filters need replacing and some of them aren't cheap. Bagless cleaners are not the great advance that everyone seems to think they are.
CROSSBONES
CROSSBONES
S.Wales
Its your own fault, you should have listened to 2cvbloke and bought a kirby!:-rofl2
Yeshi
Yeshi
kirby :-rofl2:-rofl2
Anyway i seem to of fixed the problem..
The clear hose which joins the base to the upright section was over tightened and twisted due to use..
I have spoken to dyson and they say it can twist over time.. and to take it off and untwist it..
so i have done.. apparently the over twisting will stop the base from making contact with the carpet thus loosing suction.
anyway i had half of tub of dirt... emptied it out on the carpet switched it on and bam it picked the hole lot up in seconds :)
2cvbloke
2cvbloke
Bulbs need shelter too...
Near Pontop Pike, Co. Durham
Take it to the highest window in your house, then drop it, if it is still not working, repeat this action. Afterwards, go to eBay and get a Kirby... :p
UK South
I think it's time we set up a vacuum cleaner thread, and put a couple of expert moderators in charge
Any votes ?
CROSSBONES
CROSSBONES
S.Wales
hmmmmm I used to like this forum!
It sucks now:-rofl2:-rofl2:-rofl2
2cvbloke
2cvbloke
Any votes ?
*volunteers*
:D
Yeshi
Yeshi
You cant say you dislike the odd suck every now and then..
It does seem however that vacs are talked about allot on this forum..
2cvbloke
2cvbloke
I wonder why? :D
T_G
T_G
The Consumate Dreamer
1 GigaBlue Quad plus, 1 Dreambox 5620, MOTECK SG2100A DISEqC Motor, 120 cm noname offset dish, Humax 95 cm offset dish and a few UK digiboxes.
Somewhere where the Sauer is Kraut and the Wurst is Brat
But they have cables. No cable talk on this forum??
2cvbloke
2cvbloke
Satellite boxes have cables too, so is there no talking here then? :p
