need help with gemini please
R
russ40
dreambox 500
usa
hey any one running the new gemini project 2.20 . i tryed gemini manager but cant figure it out. were do the keys and emu go or how doyou settup a gemini . dont start with you should use pi img lol i have the new tuner alps so im trying to get this gemini working. so far i got channel 101 working everything else says cant descramble soo i plead for help
W
whatsthis
DM7020 Screambox
MAC OSX & windowzz 98SE
Gemini
1664 on tap
13°E
Hi
You can load them directly if your connected to the net if not then manually load them.
I don't know if the 500 is the same as the 7020 but with your FTP progam on your PC try putting the emu and keys tar.bz2 files from the IHAD web site into the var/tmp folder. Then on your dreambox go to the manual load addons and load them into the box. reboot and select the emu you want to try.
Hope this helps, if not then a DM500 owner could tell you more.
G
gthia
Skymaster WinXP
germany
to me newcam = mgcam = cam3.
donno why they have so many. all doing almost the same stuffs.
connect to download and install from addon.
download and install the following order.
1. Emu
2. Emu config.
3. K**s. Can't mention this? : )
