need help with questions
D
duane
Likes
just starting up
burnley lancashire
#1
hi all i have got few questions, i have an echostar dish but want to test the acuator to see if it is working but i dont have a reciever yet is there any way of testing it without a recevier?
the second question is as i am only just getting in to this stuff wat is good cheap system to get looking at spending about £100 on one.
hi everyone
Topper
Topper
Amo Amas Amant Admin
Likes
3,361
IDD CI24 ECONO MM Penta 1.20 Galaxy II
1.2Mtr Polar MTG yes it has been on the arc for 25 years and is now fixed on 13 East using two pairs of rusty molegrips. Unlike me they never groan but always perform.
Blackburn, Lancashire
#2
Welcome to the forum duane
Well I know nothing about actuators as my dish is actually driven by a windscreen wiper motor, but if I was faced with your dilemma I would try to determine what type of actuator you have i.e. make model and thus required voltage. Then find a supply to suit. I would have guessed 12V, 24V or 36 V DC but that is a complete guess. Although 12V would actually be easier as a car battery is 12V DC hence easy to check out due to their being a number of cars on the roads these days:eek:. Opening the casing may reveal some details if there is no label on the outside.
As regards a system for £100, I doubt you will find one with a built in positioner for that sum of money.
D
duane
Likes
just starting up
burnley lancashire
#3
the acuator is an echostar blackjack which i think is 36 v
Robbo
Robbo
Retired Mod
Likes
5
Gravesend,Kent,UK
#4
Inside the actuator there will be a DC motor. Connecting a voltage across the motor terminals should make it move.Swapping the wires round should make it move the other way. There will be other connectors on the actuator for sensing its position, for testing you don't want to connect anything to those as it could fry the unit. The motor connectors/wires should be labelled M1 and M2 or something like that.
If its a 36V motor, connecting 12V across it should still make it move, but very slowly. Don't connect to the wrong terminals though.
