need some advice on a motorised setup
D4ftpunk
D4ftpunk
Dreambox 7020
Dreambox DM500
Sky Thomsom Digibox
StrongSat FTA Reciever
80cm Dish + 45cm Dish via Disecq A/B.
England
ok ive decided to make the jump to a motorized system as my neighbour said he will help me install it :p.
Anyhoo, i want to pickup astra2/astra1/hotbird/sirius/thor/eutelsat/astra3 and if i can pickup more thats leet, i live in central england, would a 80~cm dish do the job? or i need a 1m?.
Also, can someone recommend a nice wallbracket+motor+dish. That isnt tooo expensive.
Lancelot
Lancelot
Retired Mod
SS1.
36v H to H 62E - 61.5W
South central
1mtr is best if you can afford / get away with one as inevitably you will want something you just can't quite get with your 80 . But if you are forced then a good 80 will be ok. Have a look around see what you like and narrow it down, then have a chat about the couple you like the look of.
Depending on location dish size and what you want to drive it with anything from a cheap DiSEqC £40 to the dual axis Jaeger £180. Depends on what you call cheap as your the one with all the DB's after all :D
Worry about the mounting when you have decided what you are getting and you have made up your mind where it's going to live.
L.:)
J
john22
Samsung Motorised COMAG sl55. Panosonic TUDSB 30 Sky box.
Ireland
You will have no proplem with 80 cms as I live in Dublin [Much further West than you] and have no proplem with a dish that size and get all the Sats you listed plus lots more. Best of luck with your choice.
D4ftpunk
D4ftpunk
Dreambox 7020
Dreambox DM500
Sky Thomsom Digibox
England
ok i think im gonna go for the 80 odd cm triax solid dish, however i want a motor i can use with DiSEqC so i can turn the dish with my dreambox, and what bracket will i need?
gimme costs :p
p.s. for the last time the dreamboxes were free ;p
Lancelot
Lancelot
Retired Mod
SS1.
South central
These are not the worst in the world
_http://search.ebay.co.uk/sg2100a_Consumer-Electronics_W0QQcatrefZC6QQfromZR4QQsaatcZQ2d1QQsacatZ293QQsalicZ3
Had some good opinion on here in the past.
1 set of sturdy T & K brackets 3 feet of scaffold pole, a couple of U bolts and some Rawl bolts for the wall.
That'll probably do it.
Treat your LNB to some new CT100 while your up there and you'll be all set for the winter.
L.:)
gameboy
gameboy
Ding Dang Doo
Scotland
I got my TK bracket from Maplin for around £16 if I remember correctly.
Just checked and they have a 10" at £9.99 and a 16" at £12.99 check the dish can rotate without hitting the wall before you choose the size you want.
I used a aluminium pole from B&Q (lighter that scaffolding). Had to cut it as the shortest was about six feet! Think it was expensive at £12.
The U bolts that come with the Maplin bracket are not large enough for scaffolding.
When mounting it on the wall I used a few washers behind some of the bolts to get the mount perfectly vertical (a very important part of the set up).
Bought the motor 'brand new' off a German dealer on ebay for about £40 inc P&P
Hope this helps - GB
D4ftpunk
D4ftpunk
Dreambox 7020
Dreambox DM500
Sky Thomsom Digibox
England
Well my neighbour who is installing it with me, had to fit a wider bracket as he couldnt turn to 28.2 which is i fear the same as me as his house is in line with mine sorta.
J
john22
Ireland
I bought a Moteck SG on E-Bay for 35 Pounds Plus p+p Got it in 2 days[ E-Bay Seller fire2wire] Great motor and a dream to put up and set up. You would be advised to get the brackets local they are hevey to send through post. Make sure brackets are sturdy these motors are heavy. Having said that, you should manage it by not rushing and making sure everything is solid from the start. Good luck.
T_G
T_G
The Consumate Dreamer
1 GigaBlue Quad plus, 1 Dreambox 5620, MOTECK SG2100A DISEqC Motor, 120 cm noname offset dish, Humax 95 cm offset dish and a few UK digiboxes.
Somewhere where the Sauer is Kraut and the Wurst is Brat
Yep, the SG is good value for money...
popovp
popovp
My system:Receiver-Ferguson Ariva 102E HD, Sky Sat 9900FTA+emu;Ferguson FX-6600CR/OCTAGON SF318 soft;LNB-Sky Sat, universal, 0,2dB;1.17x1.06m offset dish ;Diseqc 1,2 +USALS Moteck2100A motor; 1,2m parabola+0,3dB Inverto @ H-H Strong SRT DM 2100
Varna, Bulgaria
I've no problems with Moteck SG 2100A.
closetosoton
closetosoton
More dishes than Sense.
Wavefield T55, 20 LNB's and a whole load of analogue boxes!
Close to Southampton
you could add hispasat to your list... cts
mhku
mhku
TM Nano ~ sg2100
Midlands
I also use a Motek SG2100 from Ebay. I used a bracket from Screwfix for about £6 and used an old piece of 30mm steel pipe for the pole.
john_graydon
john_graydon
Dublin....Ireland
Some footie popping up on 42e skyturk, maybe there is more to come ??
You should be able to get 42e to 30w without any problems. Althought some on 1w might need a 88cm dish,if they come back to us.
