NEed some advice
arunkaushal
Likes
NSS 6 DD DTH Eurobox
India
#1
Hey ppl ..
wassup.. i am new here .. so obviously need some help..
i am from india . . need to know about DTH providers here..
and the equipment.. :confused :confused
planning to buy ..
heard there are absolutely no adult channels in India? is it true??:eek: O-st
anyway.. kindly reply asap or whenever ur free ..
cheers..
ARun
W
wurzel
Likes
south west uk
#2
Hi M8,
The best thing you can do is take a look on lyngsat you should find out about everything thats available to you in your country. best luck. wurzel. :)
B
bokya
Likes
Dish tv network and FTA receiver
Mumbai (India)
#3
hi arun
I am also the new one as per you
You can get some adult channels on LM1 satellite 75 degree east check that
B
begarkitta
Likes
Hai Bokya,
More information about this LM-1 channel please!
B
bokya
Likes
Mumbai (India)
#6
begarkitta said:
Hai Bokya,
Hi begarkitta,
You just check lyngsat.com for footprint and channels list and TPs
B
begarkitta
Likes
Bokya, Analoguesat,
LMI-1 northern beam does not bless me with ample footprint area (I live in south India). How is it then that you (Bokya) get hot channels from this sat?
B
bokya
Likes
Mumbai (India)
#8
I think you should required 120cm dish atleast
B
begarkitta
Likes
Bokya,
Thanks for your reply. But really, I am intrigued. Neither Satcodx nor Lyngsat show LMI-1 with Ku band footprint anywhere over India (excepting, of course, extrem northern fringe of Kashmir). Are you sure you can catch LMI-1 with 120 cm dish?
I look forward to your adivce.
B
bokya
Likes
Mumbai (India)
#11
HI begarkitta,
Sorry for late posting I am sending you the covering map of LM 1 satellite and then you tell me how you cannot receive it
You can definately receive LM1 ku band
check out the link
B
bokya
Likes
Mumbai (India)
#12
Tell me about results you are getting form it
I think you saw their C band footprint it not cover india at all
But you can get it on 90 cm dish just try it out
B
begarkitta
Likes
Bokya,
Sorry for replying so late. I was away. There is really some confusion about LMI-1 Ku band footprint. The earlier map does indeed cover India. But the later ones (check SatcoDx) do not. In any case I do not receive Ku band from this Sat (in Bangalore).
Anyway, I shall try again. Meanwhile, can you tell me which CAM you are using to receive the encrypted channels. Where do I get them in India?
B
bokya
Likes
Mumbai (India)
#14
you can watch it on ZEE dth also
B
bokya
Likes
Mumbai (India)
#15
by using zee dth system you just do this..................
Aim your dish toward other satellite got signal quality and then do auto serch simple. I am having 90 cm dish receiving lm1 75 e satellite good luck.
B
bokya
Likes
Mumbai (India)
#16
hi Begarkitta ,
This is another new news for you from another thread look it---
I live in South India... and my dish size is just 60cm.. I got with Dishtv.... ok set your dish words Asiasat 3s and you can get the signal for 1 TP.. all the channels are in persian and 1 or 2 in arabic... It is good for people who know arabic and persian...
So be happy you can also get Asiasat 3s channels on zee dth
see that and post your reply
B
begarkitta
Likes
Thanks bokya,
Signal level is OK but those arabic and persian channels are useless. thank you very much for helping me. keep posting.
