Need some help with Humax 5400
florence
florence
Likes
i'd like to get some information about the humax 5400. Who do i handle the emu's and key-bin files?
the ToH3.2 is running. how do i put a xxx emulator on it and how do i update the key files? what software do i need (or which do you use) to update it?
any help would be appreciated,
florian
T
thewarrior
Likes
most forums will giv info on how to update the patch
then insert a new channel line-up
then key.bin file
ToH 3.3 is now available as well..
florence
florence
Likes
ok, i have the ToH 3.3 up and running. the only thing i have to do is to put the key.bin in it, right? which tool do i best use for this (i have the humax toolbox)?
best regards, florence
T
thewarrior
Likes
many thanks to the guys that wrote this......
Make sure you have the latest channel settings *pet123* (thanks to this guy), before writing the bin file (machi key bin works well). and set the CAID (in Config Menu) to CARD+EMU, with your fun card - contacts facing up in the card
There are two programmes u can use:
samyhummy edit or dsr9500emued,
using sammyhummy_edit
make sure you have changed your caid to card+emu, or card+emu+s (Config Menu)
you have a 6/1 card in the box, contacts upwards.
open the editor
load your bin
untick fast write
press the middle button bottom right with red flash
bin will load and you will see progress in red bar
when its finished
press ok.
then press 0 and (before the dashs leave the screen) rcl on your handset this will set the keys.
using DSR9500 emu edit
go to the directory where the editor is
and open the file settings(configuration settings)
change the value of fastwrite from 1 to 0
make sure the default port is correct
and fwcheck is 0
then save and exit
check the caid
now start dsr
do not tweak it other than check your com
load your bin
press write
you will see the progress in the top left as a count up progress to 100%, it wil
again do the 0 rcl to set the keys
following the sammy errors in dsr 9500 you use the empty ram option.
but other wise do the same as above
T
thewarrior
Likes
no probs
let me know if u need any help...
but make sure you load things into your humax in the correct order....
also, when u load the key bin, go to a enrypted channel - Mu***Vision
if u load the key bin successfully, this will become clear.
ensure that the CIAD is changed before hand
then store the key bin data by pressing 0 and RCL
good luck....
J
js73
Likes
Humax
Switzerland
#7
I have a Humax 5400 Z, and I have a problem using the VIACCESS CAM with the Pehla Europe (Sony) card. I was told I should change the CAID, but I do not know to what. I have tried CARD+EMU and CARD+EMU+S, but no success. I tried another Viaccess card (Swiss channels) with CAS1, which worked, but not for the Pehla Europe. The Pehla Europe card is fine (works in the neighbour's house). Is there any detailed information available about CAID somewhere? The user manual is silent on this. The ToH version is 3.3. Many thanks.
