chinna
- Nov 3, 2005
- Age
- 47
- 1 Metre Dish, Diseqc 1.2 Motorized H-H Motor, technomate 1500 CI+
- UK
Hi, just wanted some advice, so far I have set up my system. I did it by using the postion of my sly dish as a guide. I can get astra 28 e. I can get channel 126 which is ibuy tv , which is quite clear but not bbc etc. I had my motor set at 13 e as I was trying to get hotbird but ended up getting astra 28. So if i took away 13 from 28 would that give me my true south postion?. I was also wondering what i should do to align the dish?. should i move the dish via the motor manually or via the receiver?. Should i try getting all the fta channels on astra 28 before moving on etc? I have atached some pitures of my setup and view of dish. Any advice would be helpful.
Thought i would get some advice before i move on as this is a major break through for me.
Thanks for any info.
