- Dec 10, 2004
- 1.2M Channel Master, 1224 motor, VU+ Duo 2
- North West
Stealth 244 is now available with Polsat and Digi TV AU fixed.
Unfortunately I don't think this will resolve your problem as the error message "invalid CI module for this program" seems to be related to your receiver.
You should get Keys are Expired, please insert Smartcard, or something like that.
Can you enter the Cams menu using your receivers remote control?
I was assuming that you set the configuration menu using the receiver and remote, but you might have used the Cas 3 for this.
Does your receiver recognise any of the Cams you have mentioned?
