newbie dm500s and sky
Z
zwarder
Hi all, I have managed to get my sky card working with my dm500s & newcamd on gemini image.
I have a second dm500s, how can I share the card through my router?
BGonaSTICK
BGonaSTICK
Dreambox 7000, Skystar2
Brighton
You can't with NewcamD 6.0 and 6.1, but you can with 5.28.
You'll need the unofficial cardserver patch, or use GBOX or one of the other emus.
6.0 and 6.1 use Betad and sharing has been deliberately blocked. Check the NewcamD 6.0 readme for more info and reasoning.
STICK
D4ftpunk
D4ftpunk
Dreambox 7020
Dreambox DM500
Sky Thomsom Digibox
StrongSat FTA Reciever
80cm Dish + 45cm Dish via Disecq A/B.
England
I would suggest getting either newcamd 5.28 or if you wish to use gbox , get the latest version and install that aswell as cs2gbox + newcamd. Using older working versions of gbox wont be compatible with newer versions
Z
zwarder
I have got cardspider running but when the 2nd box connects to my 1st all i get is connection failed, I have forwarded port 15000 to my first box.
I get servername mismatch for some reason,
I used cardspider SETup program to do this.
Z
zwarder
I have got both boxes cardspider now logging into each other but still can't get sky to clear on the second box :(
W
wallycharlo
DM800 / 1m Gibertini XP
Western Austria
as already asked, which version of newcamd are you using ?
E
everready
you need to add an extra user. If you are only using 1 user you cant clear on both machines. Add user will different user name in cardserv.cfg and change your newcan.conf on the second box to this new user.
D4ftpunk
D4ftpunk
Dreambox 7020
Dreambox DM500
Sky Thomsom Digibox
England
dont use cardspider, use newcamd.ppc and cardserver0961.dream and edit cardserv.cfg and newcamd.cfg adding the user in both. Thats all that is needed.
Z
zwarder
ok thanks got it working after a lot of messing about
gameboy
gameboy
Ding Dang Doo
Scotland
Great - can you share how you done it with us all?
Z
zwarder
well think I cheated a bit, cardspider doesn't seem to actually do anything at all.
Z
zwarder
oh Newcamd 5.28 with cardserver0961.dream I used
