Newbie, Motor Reset
adge40
Metronic Touchbox2
80cm Dish Metronic sat motor (Maplins Bundle)
Warrington,UK
Hi
I've got the Maplin's bundle.
Metronic TouchBox2 80cm dish and a Metronic DiSEqC motor (450907). It's mounted on a 2.5 m pole in the back garden and receives no problem
I only set it up on Sunday, I had it all working, but now the motor will not move when I change satellites. I can manually change the postion but when I save the satellite it stays on that one when I try a different one
I can take it back to the shop, but I don't want to look an idiot if it's just something simple.
Has anyone else come across this problem.
Adge.
UK South
Can you send a link to the specifications, or even better, a snapshot of the menu structure.
adge40
Metronic Touchbox2
Warrington,UK
UK South
Hmmmm ' Bad CMap/encoding' on the manual links
Who is it made by ? (Korean ?)
adge40
Metronic Touchbox2
Warrington,UK
I can't see any "Made in" badges but the company is French, so I must assume they are made in France.
Lancelot
Lancelot
Retired Mod
SS1.
36v H to H 62E - 61.5W
South central
Labour charges are actually lower in the UK than in France so, unless it's a French dependancy then probably not. Not for the price Maplin are getting / selling them for in any case.
L.
UK South
Even though it looks French its going to have a 'Fabrique en XXXXX' somewhere. Box, manual, even under the receiver
adge40
Metronic Touchbox2
Warrington,UK
Any ideas as to why the motor will not return to the ref/reset position.
Is it because Mr. Blair and Mr. Chirac cannot agree that my "French" motor is taking sides and not cooperating too?
