Newbie Needs Help!
Likes
I have just had a technomate reciever installed on a motorised dish, And I subscribe to the ART sports channels. The bloke who fitted it has dissapeared from the face of the planet and left me in Sh*te with the wife. The problem is that when i'm watching a football match on any of the ART channels it regulary freezes and crashes, Then it resets itself. Anyone any idea's why? I haven't a clue.
Cheers
Likes
1,286
#2
Which model Technomate is it and are you using a separate CAM? Have you looked to see what signal strength you have on that channel?
If it is a sodtware crash, then reloading an updated version of the software may cure the problem, did the installer supply the receiver as well?
Likes
Its A Technomate TM 5500 ci Reciever with a Dragon Cam, The Signal Strength seems to be about 70- 75 %. How do you load an updated version of the software? I'm totally new to all this.
Cheers mate
Cheers
