Newbie satellite dish help (motorised)
JohnyBoy2oo6
Technomate 5000dapci
90cm dish
basic lnb
Jaeger 99 motor
Amble
Hi people
I could really do with some help setting up my dish and these forums are gr8
I have a 90cm dish
a JaeGer 99 motor
a technomate 5000dapci upgrading to 1500ci super shortly
and live in the north east of england in a town called amble
55.3326°N, 1.5760°W this is where the dish is
any help or guides to my motor would be nice thanks
will take some pick's the morn for you guys if thats any good
betas
1m orbit dish stab v motor technomate 1500 ci diablo t rex cas 3
yorkshire
firstly you say you are going update shortly to a 1500 so i would advise you install a disq moter because its easy. Any way pole should be plum set angle on mount to53 digrees dish depending dish eg 22digrees move mount to 0 (middle central postion) fix dish on in middle of mount arm look south tune 1w eg bbc world in little bit tight move east and west when found connect receiver MOTER wires move east to 28e push dish slightly up and down check signal move to 30w check signal if push up more signal move whole mount slightly eastdo oposate if up
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
