NFS Mount Problem
M
milanvora
Dreambox 500
Switzerland
Downloaded NFS Dream, Truegrid,
Installed nfsdream in c:\NFsDream
Installed Truedgrid under c:\NFsDream\nfs
Folder c:\windows\etc exists
created share: c:\dreambox
Enabled network sharing with right clicking under windows
started portmap add, nfs add
path record in exports file says: /dreambox -path=c:\dreambox
started nfs with nfs start
then entered ip of pc (192.168.0.1) and dreambox (192.168.0.101)
the tried to mount the directory with dreamnfs
but i get following error: mount: Mounting 192.168.0.1:/dreambox on /hdd failed: Bad file descriptor
Any idea what i'm doing wrong.
Thanks in advance
mhku
mhku
TM Nano ~ sg2100
Midlands
can you access 192.168.0.1\dreambox from your PC?
Why are you using NFS rather than CIFS?
M
milanvora
Dreambox 500
Switzerland
CIFS worked fine. Thanks.
