nilesat problem
Sir Bronking
Sir Bronking
Likes
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up
cheshire,algeria
#1
hi guy's
have the martians nicked nilesat
with my motor i can get satellites very close either side but cannot get nilesat (bloody city are on tomorrow so i'm in a bit of a panic as to what's wrong
any sug's (i don't say watch united):-reindeer this is important
Topper
Topper
Amo Amas Amant Admin
Likes
3,345
IDD CI24 ECONO MM Penta 1.20 Galaxy II
1.2Mtr Polar MTG yes it has been on the arc for 25 years and is now fixed on 13 East using two pairs of rusty molegrips. Unlike me they never groan but always perform.
Blackburn, Lancashire
#2
Even with a 1mtr you will struggle with most nilesat channels it is a mediterranean footprint don't even consider it a viable option for footy from cheshire
Sir Bronking
Sir Bronking
Likes
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
cheshire,algeria
#3
cheers topper,
at least i now know theres a reason why
thanx
don'tknowdon'taskme
don'tknowdon'taskme
Part Timer
Likes
DreamBox 800HD DreamBox 7025 PVR160g HD,500s Dreambox ,Sly+ Full Package,SkyCard 2, And a Eagle 500 Clone DM500 TM755,TM9100 Linux
Channel Master 1.2m,1224EL Supermount Orbit Tracking Motor With c120 Feed Horn Invacom Quad Lnb Cas3 SC Dragon Progr
that would be telling
#4
i think thats the satellite you watch the footy on in cyprus with a art card middle east satellite i have been told it takes a bigger dish and then its a weak signal.
Sir Bronking
Sir Bronking
Likes
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
cheshire,algeria
#5
i darn't get a bigger dish, the wife will kill me, maybe better cable and top notch lnb she might not notice, is it worth a try
don'tknowdon'taskme
don'tknowdon'taskme
Part Timer
Likes
#6
no m8 just checking a email i got a while back nilesat is the sat art sport is no in the middle east and u can watch it in cyprus.the only reason i know is it is only £7 a month to watch art sport on it and i checked if i could get that price here and was told you need nilesat and i will not get it i was told to just forget it.
T_G
T_G
The Consumate Dreamer
Likes
215
1 GigaBlue Quad plus, 1 Dreambox 5620, MOTECK SG2100A DISEqC Motor, 120 cm noname offset dish, Humax 95 cm offset dish and a few UK digiboxes.
Somewhere where the Sauer is Kraut and the Wurst is Brat
#7
well, with a 1.2 meter in mid Germany I get fairly good reception....
don'tknowdon'taskme
don'tknowdon'taskme
Part Timer
Likes
#8
well you are just a tiny bit closer to the sat than use.
T_G
T_G
Likes
215
#9
Yeah, I know. I tell you what, I recently adjusted the dish a bit as the elevation was slightly out, and suddenly I managed to get it. Surprised me as I did not think I should be able to get it even here...
don'tknowdon'taskme
don'tknowdon'taskme
Part Timer
Likes
#10
nice to hear that u did not give up m8 u never know till u try.
