Nokia mediamaster 9200 and DVB2000.PLZ HELP!!!!!!!
Zebo
Likes
Hello everybody. i desperately need some help with a nokia mediamaster 9200. ive been trying to load it with DVB2000 for a few days now but nothing seems to work. first i heard that the best software to do it is BDP115. so i downloaded it. but when i tried loading the DVB2000 into my nokia with BDP it asked for an LPT port configuration. but the thing is that im not using a BDM interface since the bootloader on nokia does not need upgrading cos it is B2.00UnS. so they told me this way the BDP115 is not the software i must use. so i downloaded the next best soft that as ive heard is Transbox v. 2.0.0.1.4.,but nothing works with Transbox either.
could anyone tell me if im doing something wrong here or if i can use another software to load DVB200 into 9200, maybe the firmware by nokia called SerialDownload would do? any help is appreciated.
Operating system is Windows XP, i do all the right steps as described in the manual. open Transbox, choose com(which is COM2 for me), choosing the DVB2000.bin on the software window and press Start button. then plug in the mediamaster, on the display it says B2.00UnS,Nokia,FTA2.1 and Welcome. I press connect button on transbox but instead of saying Serial on the nokia Display(as said in the manual) it doesnt respond at all. plz help if u can, thanx in advance.
Burnham Beech
Likes
Hello Zebo,
I find DVBedit easier to use than Transbox - can you try that and tell us how you get on.
But if anyone knows how to get Transbox to work please post below.
Low Profile
Likes
DM800HD, DM7000 80GB HD with Asus WL330 wifi + 2GB usb drive, Skystar2.3, 2.2m Kinhuge Dish with Inverto LNB and Invacom ADF-120 feedhorn. Pace 1.3.25 and 80cm for Sky.
Lot, Dordogne, Correze border.
#3
Nokia Serial Downloader will work in situations where DVBedit will not, ie. where corrupted software has been installed or where software disables the comm ports (like dream 5.5 on a 9500). You will of course need a null modem cable. I had no problems with win 98, don't know about XP though. IMO beta8_np52.bin is the best DVB2000 O/S.
Zebo
Likes
thanx for ur interest guys. i tried to use the DVBedit as u had told me before but it says there that i can only load the settings with this program, will it work if i try to load the DVB2000 into nokia9200 with DVBedit? id also like to ask if i can load this nokia with DVB2000 using the firmware Serialdownload by nokia? thanx in advance
Burnham Beech
Likes
nhfs49 has posted a guide here which might help.
http://www.satellites.co.uk/php-bin/forum/showthread.php?t=37404
If you want to continue to try DVBedit I can try to help. What version of DVBedit do you have? When you open DVBedit you see a Serial tab along the top. When you click serial you should see "Upgrade Firmware". Have you tried that yet?
Zebo
Likes
Thanx a lot man, i appreciate ur help. i used the serial download to load DVB2000 and it worked. thanx again
