elvirisimo
- Nov 18, 2004
- Age
- 53
Djlemur,
I hope I am not to late with this
[TUNE] tuning to 12584000/27502000/V/3@-430
set continuous tone OFF and voltage to 13V
Vertikal
Hi Band
DiSEqC Switch cmd = 00f1
Entry for -43,0° not in Rotor Table found... i try gotoXX°
siteLatitude = 51.590000, siteLongitude = 4.270000, 317.000000 degrees
azimuth=234.127090, elevation=16.675711, declination=13.533855, PolarmountHourAngle=231.468702
RotorCmd = d338
Rotor DiSEqC Param = d338 (useGotoXX)
2 DiSEqC cmds to send
no Toneburst (MiniDiSEqC)
ROTOR RUNNING EMIT
[FONT] creating new font color cache entry 50253a4d .. 00ffffff
[FONT] creating new font color cache entry 504a6377 .. 00ffffff
Rotor Cmd is sent
FE_SET_FRONTEND OK
<-- tuned
[ENIGMA_DYN] lockWebIf = 0
[ENIGMA] starting httpd
[TUNE] tuning to 11937000/27502000/H/3@130
Horizontal
Hi Band
DiSEqC Switch cmd = 00f3
Rotor DiSEqC Param = 04 (use stored position)
ROTOR RUNNING EMIT
Rotor Cmd is sent
FE_SET_FRONTEND OK
<-- tuned
[FE] evt. failure
[FE] RotorPos uninitialized (0)
FE_SET_FRONTEND OK
[SERVERSOCKET] incoming connection!
[TUNE] tuning to 11939000/27502367/H/3@130
Horizontal
Hi Band
ROTOR RUNNING EMIT
Rotor Cmd is sent
FE_SET_FRONTEND OK
<-- tuned
[eAVSwitch] setInput 0, avsfd=20
[LCD] set brightness 133, contrast 23
[FE] evt. locked
[FE] start check locktimer cur snr is 49234
[FE] checkRotorLock SNR is 39009... old was 39234
[FE] rotor has stopped..
------------> changed! f
-------------------Set ECM-----------------
[TUNE] tuning to 12698000/4340000/H/2@360
Horizontal
Hi Band
Rotor DiSEqC Param = 01 (use stored position)
1 DiSEqC cmds to send
ROTOR RUNNING EMIT
Rotor Cmd is sent
FE_SET_FRONTEND OK
<-- tuned
request = GET, path = /data.js
translated /data.js to /share/tuxbox/enigma/htdocs/data.js
[FE] evt. failure
FE_SET_FRONTEND OK
[FE] evt. failure
FE_SET_FRONTEND OK
I am fighting with my dreambox 7000s with HH100 and Gibertini 100 cm dish. If there are other thing you would like me to check - please feel free. Only problem is that I have my motor/dish on the roof (can't reach it easily). I am new to drambox scene, but linux is my preferded solution - for more than 10 years.
Vertikal
Hi Band
RotorCmd = d338
ROTOR RUNNING EMIT
Rotor Cmd is sent
FE_SET_FRONTEND OK
<-- tuned
Horizontal
Hi Band
ROTOR RUNNING EMIT
Rotor Cmd is sent
FE_SET_FRONTEND OK
<-- tuned
[FE] evt. failure
FE_SET_FRONTEND OK
Horizontal
Hi Band
ROTOR RUNNING EMIT
Rotor Cmd is sent
FE_SET_FRONTEND OK
<-- tuned
[FE] evt. locked
Horizontal
Hi Band
ROTOR RUNNING EMIT
Rotor Cmd is sent
FE_SET_FRONTEND OK
<-- tuned
[FE] evt. failure
FE_SET_FRONTEND OK
[FE] evt. failure
FE_SET_FRONTEND OK
